2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T09:57:36+00:00
    Also have this issue.
    Though I have checked the version numbers for the different devices, and they seem to have all 'updated'. So I'm unsure which part of it failed.
    Surface Pro 2:
    • Intel HD Graphics (v10.18.10.3345)
    • Improved system stability, including minimizing full screen games.
    • Color fidelity improvements for all applications. Enhanced audio experience when connected to a Display Port 1.2 device.
    • Marvell AVASTAR WiFi and Bluetooth Driver (v14.69.24049.160)
    • Wi-Fi driver update for an improved Wireless Display experience and connectivity with Wireless Access Points.
    • Surface Type Cover 2 Firmware Update Device (v2.0.266.0)
    • Surface Touch Cover 2 Firmware Update Device (v1.0.280.0)
    • Optimized two finger track pad use.
    • Surface Pro UEFI (v 2.04.0250)
    • Surface Pro System Aggregator Firmware (2.03.0650)
    • Surface Pro Embedded Controller Firmware (23.07.50)
    • Improved Surface Cover Interaction including power-saving sleep functionality.
    Per MS Post about Update
    Seems like for me all updates got installed except Surface Type Cover 2. I have version v2.0.51.0 instead of v2.0.266.0 under Surface type cover filter device. Does anybody have this issue.
    I got the same as you except my type cover 2 is 2.0.208.0 (touch cover doesn't exist). All other versions are lining up. The update says failed. Very confused.
    2013-12-19T10:20:16+00:00
    I've just received this firmware update dated 24 Oct 2013 also, so decided to try installing it. A big, big  mistake   :-(   My Surface Pro 2 128GB was starting spontaneously, but otherwise seemed to be working OK. When I saw the update offered I assumed Microsoft was offering it to cure the issues that resulted from the December updates.
    My Surface Pro 2 bluescreened on the restart after installing that update with this message:—
    Recovery
    Your PC needs to be repaired
    A required device isn't connected or can't be accessed
    Error code 0xc0000185
    You'll need to use the recovery tools on your installation media, If you don't have any
    installation media (like a disc or USB device), contact your system administrator or PC
    manufacturer.
    Press the Windows key to use a different operating system
    Pressing the Windows key just results in the screen flashing between the bluescreen and "Please wait" - there is no different OS, of course.
    I was able to get to the maintenance screen and did a refresh, but am still getting the same bluescreen. I note that the error code I'm seeing is different to what most others on this forum have reported, but others have reported the same code as me on other forums.
    As a Technet subscriber I have a Windows 8.1 RTM DVD. Connecting my external DVD drive lets me boot off the DVD, but the repair functions do not fix the issue. I didn't expect them to, as this is most likely a problem with the flashing of the firmware ROM.  But I thought it was worth a try, even if only to prove that function didn't fix the issue.
    I was surprised to see, on the Reset Screen, two instances of W8.1, as follows:—
    Reset your PC
    Choose a target operating system
    Windows Recovery
    Environment
    Windows 8.1
    on volume 4
    Windows 8.1
    on volume 4
    Why the duplication of W8.1  ??
    Perhaps this is connected with the offer to use a different OS.
    But when I attempted to run Reset I get the a message that due to a problem the unit could not be reset.
    While I could reload W 8.1 from my DVD I suspect that will not cure the issue (and may affect the warranty on my 3 week old unit.)
    Any suggestions for further repair attempts?
    Thanks, Lionel Modra
