2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T09:14:29+00:00
     Similar to someone modifying your body's physical genes making you blind or deaf or causing chemical imbalances in this case giving you insomnia. It's not software on HDD and can't be unlearned, another reflashing of unit's ROM is required.
    That's why I'm blind! Microsoft altered my genes! When are they going to release a genes update?
    2013-12-19T09:55:08+00:00
    I didn't reset, my update appeared to complete OK but when I look at the log, it says failed.
    However my versions (except type cover, touch cover doesn't exist) are as per what you state they should be, and I have not actually noticed anything wrong except for not sleeping automatically. (It sleeps fine if I hit the button).
    Really weird.
