2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T09:10:27+00:00
    Josh,
    Thank you,
    Tim
    Hi Tim,
    This is very reassuring. Thanks for the update. I look forward to the update - hope it fixes the myriad of issues arising since the update!
    2013-12-19T09:13:36+00:00
    Thanks Tim to give us a feedback and glad to see that MS team is commited to deliver a fix quickly as possible.
    The Surface 2 is a premium hw product and I imagine your efforts and professional pride to launch to the market an excellent product and support, so please take care not to neglect the quality of the updates.
    And now let's take a breather the surface team, everyone makes mistakes, the important thing is the commitment to solve them.
    We have to have some patience.
