2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T02:35:09+00:00
    Add another.  Firmware update shows as failed and not available to try again.  Ran the patches today but did not have my Touch Cover 2 attached when running the updates.  Same update error code 80070490.
    My drivers are all showing the same version numbers as above, except for Surface Touch Cover, it shows as 2.0.51.0 (not the newer 2.0.266.0)
    Surface Pro 2 256GB
    2013-12-11T02:35:39+00:00
    Mine failed also, just like my 4 surface 2's that this pro 2 replaced
