2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T08:28:21+00:00
    Thanks- I am having the sleep issue so will look forward to a fix - really great device but this issue is a massive let down - hoping for a more robust & fully stable device in due course....
    2013-12-19T08:28:52+00:00
    OK, I got the telemetry driver to install (there was a missing device driver in my Device Manager, I pointed it to the downloaded folder, and it installed).  This didn't solve the problem though, the battery is at 10% so I can't unplug it, and when I try to do any updates it says "charge your battery full"
    NICE CATCH 22 microsoft.
    I'm going to a retail outlet to see if they'll give me a new one.
    Lame.
    SP2 out of the box here... no updates of anykind.
    No device called "Surface Cover Telemetry"
    Did MS change its name? What do you guys think?
