2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T08:00:04+00:00
    I can report that Microsoft are reinstalling the original firmware dated 24/10/2013. I just received it through windows update.
  2. Deleted
