2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T07:27:58+00:00
    We appreciate community efforts to address this issue but resetting the device will not change the firmware version which is on your system.
    Josh
    Can someone explain this for a PC noob.  I thought a "reset" was a factory restore.  Wouldn't that also roll back the firmware to its original state out of the box?
    Was thinking of doing a reset now that the update was pulled, but maybe I will not go through it if this is the case.
    A Firmware modifies your unit's protected ROM, a process called Flashing often done safely outside of the operating system (before windows starts up). But this process can go wrong if the new ROM is faulty. Similar to someone modifying your body's physical genes making you blind or deaf or causing chemical imbalances in this case giving you insomnia. It's not software on HDD and can't be unlearned, another reflashing of unit's ROM is required.
    2013-12-19T07:46:50+00:00
    In the meantime, what is the recommended action to ensure that no damage is done to the machine? Is it safe to shut the SP2 down completely after each use to prevent the overheating issues that we have encountered?
