2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T05:47:54+00:00
    A pure guess is that many are affected. Which is why MSFT pulled the update.  I bet many haven't even noticed the strange behavior.  It is ironic that the morning of my installation of last week's Patch Tuesday I was just on a call that involved the Surface team.  At the end of the meeting, I said, "... notice anything strange with the battery meter after installing Patch Tuesday? ... ". Got nothing at that time.  Maybe different now.  Maybe Stevie B can better answer.
    2013-12-19T07:09:54+00:00
    Josh,
    Thank you,
    Tim
    Hi Tim,
    This is very reassuring. Thanks for the update. I look forward to the update - hope it fixes the myriad of issues arising since the update!
