2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T04:42:15+00:00
    I read from Arnold001, who was stuck on 6%, found resolution (at least I'd guess temporarily) using the "Sound up + power button".  I'm not sure if you've tried this.
    To do this, turn off your system first, then press and hold your volume rocker in the "volume up" direction and simultaneously press the power button.  Hold for many seconds.  You will see the screen flash and maybe briefly see a screen with several options.  Continue holding (ie, you could be holding these buttons for 20 seconds). Then release your hold on the two button.  Wait 5 seconds.  Your surface should boot up.  If not after 10 seconds, press the power button to turn on.
    Once back in, open your DOS prompt (go to search and run CMD (open as administrator)) run "Powercfg  /batteryreport".  Run time is like 1 second.  It creates a html file (you may need to move this file to a different directory to allow your browser permission to open) which will report your "Full Charge Capacity".  It should read at or near 40,000 mWh.  Your "Design Capacity" hopefully will read 42,002 mWh.  Your "Full Charge Capacity" ought to be less than "Design".
    Anyway, hope you see your system charge back up to the "Full Charge Capacity" number (which should be your 100% battery level).  This approach has worked for many of us but we are observing a few select variations.  This work-around is temporary.  By no means a full solution.  I too am near exercising my warranty rights.
    2013-12-19T05:17:24+00:00
    i really wonder how many ppl and many percent of the SP2 customers are having this issue and ultimately why?
