2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T03:01:12+00:00
    Best bet is to:
    1. Reset your SP2, install the Surface Cover Telemetry Driver via "October2013SurfacePro2.zip".
    2. Change your Windows Update settings to "Check for updates but let me choose whether to download and install them."
    3. And leave it at that until the next updates arrive.
    Can someone tell me how to install the Telemetry Driver with the INI in there?
    I went into device manager and updated my firmware in all categories by searching the folder that I downloaded via the link above.
    2013-12-19T03:08:48+00:00
    OK, I got the telemetry driver to install (there was a missing device driver in my Device Manager, I pointed it to the downloaded folder, and it installed).  This didn't solve the problem though, the battery is at 10% so I can't unplug it, and when I try to do any updates it says "charge your battery full"
    NICE CATCH 22 microsoft.
    I'm going to a retail outlet to see if they'll give me a new one.
    Lame.
