2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T02:31:54+00:00
    My main problem has been that the sleep function has been very buggy. It is always waking up from sleep an hour later. I have a temporary fix that shouldn't be needed but it seems to be working as far as sleep issues. I do not hibernate my Surface, but the hibernate function seems to be the problem...
    In Advanced Battery Options, in the "sleep" option there is "hibernate after" I set both figures to 1440 minutes (24 hrs).
    It appears to me that when on battery, the stock setting of "hibernate after" is set to 60 minutes, this is the exact amount of time I noticed the Surface turning back on when it was supposed to be sleeping. This is the only figure in power settings with a one hour default setting at least under balanced plan. After switcing this, my Surface Pro 2 now sleeps through the night or when I go to run errands. I have had a few other sporadic problems but not much. This has allowed me to actually wake my Surface up in the morning and still have power.
    2013-12-19T02:40:34+00:00
    Dear Josh,
    As it seems like a holiday is so important to you and/or the Surface team,
    why did you just release such a comprehensive and critical (firmware) update with a huge impact just before the holidays?
    I suggest that no one goes home before this critical problem is resolved.
    Your comment comes across as a librarian and certainly not as a Microsoft employee/programmer with passion.
    Just fix it!
    Regards,
    Wally
