2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-19T02:17:10+00:00
    To ensure the best experience for our customers during the holiday season, we have taken steps to remove the update for Surface Pro 2 that was previously published through Windows Update on December 10^th^, 2013. We are working to release an alternative update package after the holidays.
    Josh
    Josh - This is embarassing for Microsoft. The faulty firmware update has completely ruined a brand new device (built by MS so you should expect a 1st class support).
    I kept saying how good was the device to everyone I had around and I was really hoping that this was a turning point for MS to gain marketshare in the tablet space but after this episode I will just wait an update to fix it and sell the surface pro2 asap.
    I've mainly bought the surface pro 2 to work during these holidays....but it looks like I will have to wait your patch to have the battery working again....it is just ridiculous.
    I'd suggest to the team that released this update to consider other jobs.
    I've spent to much on this thing to give up but I have to admit Microsoft has blown it.
    Josh
