2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-10T20:08:21+00:00
    I tried the new firmware update and guess what, failed to install. This is so frustrating for a 1300 dollar pc from MSFT to be plagued by issues. I'm not even sure how to force the update to install again as it is no longer showing in the updates list....
    System Firmware Update - ‎12/‎10/‎2013
    Installation date: ‎12/‎10/‎2013 2:55 PM
    Installation status: Failed
    Error details: Code 80070490
    Update type: Important
    These updates are released by PC manufacturers to help improve the stability and performance of PC hardware.
  2. Deleted
