2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-11T23:33:15+00:00
    Any chance to get the drivers pack ?
    Please msft...
    2013-12-11T23:15:52+00:00
    I followed the steps and it seems to have fix this issue, the only thing I noticed is that instead of Firmware update, now is shows as Hardware update, I guess its the same thing
