2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-12T03:23:08+00:00
    After stopping windows update, deleting the file, running the troubleshooter and then disk cleanup I was offered the update again - but like alexware it said hardware update not firmware update.  It installed ok, and now the versions of all the device drivers listed above are correct.
    My surface hasn't failed to wake from sleep or go to sleep yet either.  Hopefully this one is now sorted!
    2013-12-12T02:43:05+00:00
    I posted the fix to get the firmware update to reappear earlier and install successfully.  Unfortunately I have been having nothing but problems since these updates installed.   My system is now blue screening and the touch pad does not always work when booting up or waking even though the keyboard works.  This is on top of the unexpected shutdowns(Event ID 41) during wake or sleep randomly.  My system is much more unstable than it already was.
    Fault bucket , type 0
    Event Name: BlueScreen
    Response: Not available
    Cab Id: 0
    Problem signature:
    P1: 9f
    P2: 3
    P3: ffffe00000cb61e0
    P4: ffffd000206b2840
    P5: ffffe0000350b700
    P6: 6_3_9600
    P7: 0_0
    P8: 256_1
    P9:
    P10:
    C:\Windows\Minidump\121113-7500-01.dmp
    C:\Users\David\AppData\Local\Temp\WER-23265-0.sysdata.xml
    C:\Windows\MEMORY.DMP
    C:\Users\David\AppData\Local\Temp\WER5D81.tmp.WERInternalMetadata.xml
    These files may be available here:
    C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Kernel_9f_751de5b9e263aaa77d8628f6be286ac8499b083_00000000_cab_0c1cdaa0
    Analysis symbol:
    Rechecking for solution: 0
    Report Id: 121113-7500-01
    Report Status: 100
    Hashed bucket:
