2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T04:28:48+00:00
    Maybe folks should say what continent they are on.  It seems like many of the people having the worst problems are in Australia.  I'm in the USA and although I check Windows Update several times a day, I've never received a rollback to anything on 24/10/2013 and the fact that most people use this date format when talking about it leads me to guess that the update being issued outside the USA. (or the state of your machine determines whether you see the update)  I had the failed 12/10/2013 update and the next day or so I got a "system hardware update" on 12/11/13, dated 12/10/13.  Kinda hard to look back in time because the Disk Cleanup recommended by Dylan Tullberg erased my Windows Update history.
    Also in bagging and after bagging my Surface Pro 2, I realize I never thought very much about where I grad the case.  Aside from horrifying problems like the ones described in this forum, it seems it's very easy to turn on/wake the device by being careless about how you grab it.  Having the thing on and in a bag is a recipe for a positive feedback loop.   So in future versions, maybe (aside from the problem here), maybe Microsoft should give more thought to the Power button design and make it less easy to accidentally turn on.  I've done that both with my SP2 and my RT device upon occasion.
    2013-12-20T03:55:01+00:00
    My Surface Pro 2, whicn I bought from Harvey Norman, Adelaide, is being replaced , but no stock in Adelaide. They hope to get me a replacement from their Mount Gambier store next week.
    No updates will be applied to the replacement until I hear that Microsoft have fixed the problem !!!
