2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
  1. Deleted
    2013-12-20T04:40:43+00:00
    Wow, this thread really explains why my battery meter keeps jumping up and down and all over the place. I can't even trust it to tell me the real amount of battery life that is left.
    The overcharging stories are seriously scary. If not just damaging your battery, they could start a fire and cause the battery to burst. In my case, thankfully, all I'm observing is the battery meter that decides the current charge level is always 100% after waking up, and produces proportionally shorter apparent battery life (but at least the battery report shows the real state of charge.) I followed the previous advice to go with hibernation instead of sleep for now and it seems to be working.
    P.S. Massive pile of refurbished Surface Pro 2's incoming...should help with that supply/demand imbalance we all worked so hard to get around, right?
