2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T07:26:15+00:00
    Ok, everyone saw my earlier angry posts.
    I have to say, I called Microsoft support and the put me through to someone to help.
    NOW, now, bear in mind that I had already reset the surface pro 2 to factory, and done the updates. But the guy I spoke to at the Surface team said they knew that this was a trending issue, and that I should uninstall my battery drivers, unplug my surface, power it down and leave it off for 15 minutes. then, he said to plug it in and let it charge for 15 min and see if that fixed it,.
    I used to work in IT and thought this was the most BS solution ever, but I was willing to try anything.
    I can't believe it, but it worked. The Surface team even called me back today to check in on the status.
    While I am super annoyed about the patch messing things up, I have to say the support from surface team was pretty good.
    Surface Pro 2 back in action, and Windows updates set to "let me decide when to install the updates".... will be that was for ever.
    Smart guy! That makes sense.
    2013-12-20T06:58:09+00:00
