2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T12:17:39+00:00
    matthew,  did this also fix the waking from sleep issues?
    BTW,  I have been experiencing the waking from sleep since installing the 12/10 firmware update.  I have tried all the fixes except for a complete reset as I really do not want to go thru the hassle of reinstalling numerous programs again.
    I have a 128GB surface 2 pro
    2013-12-20T12:15:07+00:00
    I've now gotten the computer to restart using the two-button method described at http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-pro-wont-turn-on#shutdown
    The battery indicator is very low.  If it charges, I'm OK for now.  If it doesn't charge, it is unusable.
