2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2013-12-20T13:30:00+00:00
    I was not aware of the issue everyone was having.  When I got the "Battery at 5%; Plugged in but Not Charging" message I went to MS online support.  They said that they needed to replace the hardware.
    They shipped me a replacement in two days.  I have not booted it up yet, but I wonder if the firmware update is already installed.
    Fortunately my Surface Pro 2 started working again the next day and has been fine till yesterday.  Now my battery indicator shows that it is low, but it still keeps working.
    2013-12-20T13:24:23+00:00
    I've now gotten the computer to restart using the two-button method described at http://www.microsoft.com/surface/en-us/support/warranty-service-and-recovery/surface-pro-wont-turn-on#shutdown
    The battery indicator is very low.  If it charges, I'm OK for now.  If it doesn't charge, it is unusable.
    The computer is charging, so I may be OK for now.
    But I have a question about firmware updates.  If I have a system backup to an external hard drive that I made a few days before the firmware update, does restoring from that update undo the effects of the firmware update?  Or does the firmware update make other changes such as to the BIOS that can only be fixed by a new firmware update?
