2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T00:20:48+00:00
    Sorry for upset. IMHO, MS Surface is the only tablet which really powerful as a regular notebook/desktop. Nobody builds something like this right now. But this is startup time. Wait next month and they will fix it all. I use SP2, my wife uses Apple Macbook and I have much more problems with hers laptop. But you're right - powercfg and yada, yada just now.
    Alexander.
    2014-02-11T23:35:56+00:00
    Hi, Al
    Am not worried about my SP2 temps.  Was replying to Rafa Roma's comment that he thinks his SP2 runs hotter after the Feb. firmware update.  I haven't noticed any temperature differences.  Any temp worries I would have would not be about the processors per se but the effect on overall temp of the device and battery life.  But my SP2 is doing great temperature-wise.  Only time I ever hear fans come on is occasionally upon Shutdown.  Weird as it doesn't seem to be connected to how much the device has been used???
    Hope Microsoft builds a better natural interface to battery state into upcoming Win8 updates, 2015 Threshold, yada yada.  The average Win8 consumer users is not going to want to mess with Administrative Command line prompts ("powercfg") or esoteric utilities like CPUID.  All the stuff essential to following the state and health of your device should come baked in in a readily discoverable, easy-to-use interface.
