2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T01:28:56+00:00
    BTW, don't know if everyone following this thread is automatically hooked up to follow the "Windows 8.1 - Strange Charging Issue" thread.
    But in that thread Steven_B, a Microsoft Forum Moderator, is urging everyone to be sure to install the February firmware update as he says it addresses the issues of incorrect charge level being reported by the battery status indicator:
    http://answers.microsoft.com/en-us/surface/forum/surfpro2-surfhardware/surface-pro-2-windows-81-strange-charging-issue/5d922bc6-15a8-47d7-8c19-1080d81dfcf6?page=8&msgId=0f27571f-2440-4030-87b6-2ad6da7585f8
    EDIT:  Looks like the man himself visited this forum while I was composing this post!
    2014-02-12T01:28:41+00:00
    Greetings all,
    Please download the February Windows Updates. You may need to install current updates, restart then check again to get all of the updates.
    Once you have all Windows Updates installed, please let us know if you are still experiencing the following:
    Firmware showing as failed in Windows Update
    Battery gauge on your Desktop showing incorrect time/battery levels
    If your Surface will not go into Sleep while idle
    If your Surface will not go into Hibernation.
