2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-02-12T02:59:28+00:00
    Greetings all,
    Please download the February Windows Updates. You may need to install current updates, restart then check again to get all of the updates.
    Once you have all Windows Updates installed, please let us know if you are still experiencing the following:
    Firmware showing as failed in Windows Update
    Battery gauge on your Desktop showing incorrect time/battery levels
    If your Surface will not go into Sleep while idle
    If your Surface will not go into Hibernation.
    Well, last night Microsoft Support assisted my with my Dec Firmware "Replacement SP2/500GB" malfunctions necessitating a COMPLETE RESTORE TO FACTORY Settings.  So I'm back to square ONE.  It downloaded 24 Updates just to Install.  Today, I see the latest update.  So, after doing some basic installs of Microsoft Office Pro 2010, I needed to add those updates... and decided that since I'm already back to square one, I went ahead with the Feb Firmware download... guinea pig.
    So far so good.
    I'll keep you posted.
    [UPDATE...  a few days later]
    Things are working AOK.  No crashes (no error 41 logs).  Sleep works.  Wifi and Bluetooth work.
    2014-02-12T02:47:01+00:00
    Just installed the 12^th^ of February firmware update and I got the "sleep of death" problem back I had on the 10^th^ of December firmware update.
    Need to restart the SP2 fully every time it goes to sleep. Now it actually does not wake up from sleep at all. On the bad December update it actually woke up sometimes after a while.
    The "sleep of death" problem was ‘”fixed” after the 18^th^ January update, and have not had many issues with the sleep problem before today.
    Michael
