2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T17:05:49+00:00
    its a windows update. it'll be there until it gets superseded by another update. what would be the point of updates that are only there for one day? forcing people to be online every patch Tuesday? ;)
    I believe they are not releasing it to everyone at the same time, considering how bad it went last time. so they're getting feedback and can stop the rollout if there are more issues without affecting everyone.
    2014-01-20T16:49:55+00:00
    Has anyone who did not get the 18 January firmware update by 18 January have it show up later?  In other words, is there some continuous roll-out underway, or was there just a release to some by 18 January and no further release since then?
