2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T17:13:18+00:00
    I'm in the merry company of those who have received the December firmware update, which failed, have received the re-release of the October hardware update, which succeeded, but did not have any effect on the sleep and battery issues, and so far have not received any January firmware update.
    This is what I have in the update history concerning firmware/hardware updates (European date format):
    Name - Result - Installation date
    "System Firmware Update - 22/10/2013" - Succeeded - 22/10/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 25/10/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 10/12/2013
    "System Firmware Update - 10/12/2013 "- Failed - 15/12/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 04/01/2014
    So, the "System Hardware Update - 24/10/2013" in my case was actually installed three times, one before and one after the December Firmware Update. Is this comparable to what other people have received?
    Thanks!
    2014-01-20T17:06:20+00:00
    According to ZDNET, the company is sending out the updates in waves, rather than all at once, and more updates may follow."
    Public releases in waves are frustrating for end users.  It's the evening of 20 Jan here - and still nothing new in Windows update.
    Microsoft need to act more like Apple.  i.e. Release pre-release quietly to their MSDN/TechNet users game enough to try it,, and then release to the public when they make the public announcement.
    There are a number of reasons for this sort of thing, including concern over server overload, BUT frequently this is  done JUST IN CASE there is a FUBAR.  That way not everyone is affected.
    In other words, a lame attempt at covering their you know what's.
    Meanwhile, no update here.  In addition I could swear i hibernated last night but woke to it being very hot and on.
