2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T17:22:17+00:00
    its a windows update. it'll be there until it gets superseded by another update. what would be the point of updates that are only there for one day? forcing people to be online every patch Tuesday? ;)
    I believe they are not releasing it to everyone at the same time, considering how bad it went last time. so they're getting feedback and can stop the rollout if there are more issues without affecting everyone.
    "considering how bad it went last time"....ms told us it was 0.3% of surfaces pro2 with the botched FW problem!
    That is a very small amount of server time compared to Toxic Tuesdays releases to all Win 7/8 and a couple of vista computers worldwide...I can not see server overload anywhere! In fact I can not see he patch here at my location after almost 1 week since the "promised" release...Where is the spokes person Josh??
    Missing in action along with ms!
    2014-01-20T17:20:11+00:00
    I'm in the merry company of those who have received the December firmware update, which failed, have received the re-release of the October hardware update, which succeeded, but did not have any effect on the sleep and battery issues, and so far have not received any January firmware update.
    This is what I have in the update history concerning firmware/hardware updates (European date format):
    Name - Result - Installation date
    "System Firmware Update - 22/10/2013" - Succeeded - 22/10/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 25/10/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 10/12/2013
    "System Firmware Update - 10/12/2013 "- Failed - 15/12/2013
    "System Hardware Update - 24/10/2013" - Succeeded - 04/01/2014
    So, the "System Hardware Update - 24/10/2013" in my case was actually installed three times, one before and one after the December Firmware Update. Is this comparable to what other people have received?
    Thanks!
    I saw the 10/24 HW update once, then the FW update -- which succeeded, then the HW update (succeeded) and AGAIN the HW update (which I hid since everytime I have a WU I lose BT and wifi until i disable, and re-enable Marvell).,
