2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T19:08:11+00:00
    Has anyone who did not get the 18 January firmware update by 18 January have it show up later?  In other words, is there some continuous roll-out underway, or was there just a release to some by 18 January and no further release since then?
    It is looking like access to 1/18 firmware is dependent on your Update History.  If you show a System Firmware Update - 12/10/13 as Failed and a later System Firmware Update - 10/24/13 as Successful even though your firmware drivers are dated November, then it looks like your SOL.  My predicament, am I left waiting for the 1/18 firmware driver package to be posted for manual install?
    2014-01-20T18:04:45+00:00
    So just an update from me.
    I returned my surface pro 2 for a full refund from the retailer, I then went and got a HP split which has really bad battery life, returned that and ended up with a Asus Transformer T100 <--- I love this machine, sure it is only 32bit quad core Atom with 2 gigs of ram but if you are using it for email/web/youtube/word/excel and a little bit of gaming (from the windows store) you can't beat it on the price. It was $700NZ for 64gig ssd in the US its around the $350-$400 mark.
    Has no problems that I have found so far and it even comes with MS office home/student.
    So all up I have a machine that I love, that works, and a nice fat refund of about $700
