2013-12-10T19:14:53+00:00
2013-12-19T06:53:02+00:00
Josh,
Thank you,
Tim
2014-02-15T00:49:31+00:00
Greetings all,
2014-02-13T22:35:08+00:00
997 additional answers
    2014-01-20T20:06:15+00:00
    Just received mine, October firmware only. So far so good.
    2014-01-20T20:04:12+00:00
    Update from me: I just got the update :-)
    It looks like there is a continuous push of this firmware update. I really hope it works...
