Surface Book 2 - Fans are noisy / loud after update
2020-06-25T21:44:20+00:00
I updated my surface book 2 (13 - i7 - 1050) today from the build 1809 to 1909 with all updates/firmware.
I have noticed that the behavior of the fans has changed.  My laptop got a lot noiser during load and even audible at idle.
Now the fans are extremely noisy/loud at load even when i'm changing the power modes (slider)
For example, on the previous build 1809, I was playing Witcher 3 in better performance mode and fan noise was perfectly acceptable.
Now regardless of the power mode, the fans are very loud.
I don't think i'm the only one with this problem.
Some examples :
https://answers.microsoft.com/en-us/surface/forum/all/surface-book-2-gpu-fan-extremely-loud/e1a4ba7b-f5a0-44c6-9f38-d645d977eca5
https://answers.microsoft.com/en-us/surface/forum/all/surface-book-2-fan-heat-issues-since-intel/20a5a632-de26-445e-90f9-2c1ff338a54b
https://answers.microsoft.com/en-us/surface/forum/all/surface-book-2-the-fan-wont-turn-off/0a58013c-1664-4eb1-8255-eb0e43c5fb85
The only solution found by the community is to restore a previous version ( build 1809 whose support will end at the end of the year).
I would like microsoft provide a real answer other than launching their diagnostic tool and i hope they will record it as an issue in order to follow the resolution. https://support.microsoft.com/en-us/help/4055398/surface-book-2-update-history
And if someone has an idea / solution I am interested ! Thx.
Regards,
Frederic
    2021-04-14T05:17:19+00:00
    if you try  for a refund  or  a exchange  they will refuse  refund  and if your surface is  new  they will  send you a refurbish
    I have a surface go bought in march had nothing but problems. they are very uncooperative, and have decided to replace my surface go with a refurbish product a $699.00 product for a $1200 product.I wanted a refund they have refused stating Microsoft does not give refunds nor replace with new items. Um my device was new and had less than 1 week use. It is time to see a ombudsman to make a formal complaint., on how Microsoft is money hungry and takes advantage of the disabled and time to go public with it. I will be making many reviews about how microsoft handles. What microsoft does not understand it was bought through NDIS and so government may also take action folks beware Microsoft does not honour their word
    They have refused a refund
    as you see they have ripped off a disabled  person
    Microsoft is so money hungry
    I am going to talk to a ombudsman to handle it
    I have been on to  Microsoft  since  first week  poor quality devices
    2021-04-14T05:18:14+00:00
    not going to laugh
    really I am not
    2021-04-14T05:22:58+00:00
    I had battery issues after 2 weeks  of tech support  doing the same tests
    I showed them  battery report which they forgot  to do
    it showed the  battery had up to a 4 hour life expectancy
    they have the same patter  and are told  not to give refund...
    best thing I can recommend is warn  people.
    if you are a better system try
    samsung flip top or a asus zen book
    better q uality  and better after service
    2021-04-14T05:48:00+00:00
    My old surface pro 4 has the screen flicker problem, Microsoft refused to fix it. Now it's a paperweight.
    The SB2 had issues with the touchscreen on the main monitor when having a second display connected, it got fixed after like half a year, now there are serious lag issues when using skype for video conferencing and screen sharing, it feels like I'm using a pentium 3 with windows 2000 sometimes.
    Now the fan is going crazy.
    I'm so tired of surface products at this point, I regret my purchase of both Surface products.
    2021-04-17T09:38:27+00:00
    Hey guys, disabling "Game Mode" seems to have worked for mine. I found this suggestion on Reddit from last year, and thought it would be worth a try:
    https://www.reddit.com/r/SurfaceGaming/comments/gyi8po/support\_surface\_book\_2\_battery\_drain\_and\_high\_fan/
    "I read somewhere on Forbes that the May Windows 10 update screwed up a lot of communication/compatibility with BOTH Nvidia GeForce and Intel core refresh rates. They fixed this by disabling Game Mode in Windows Settings (Settings --> Gaming --> Game Mode) at the sacrifice of framerates. This isn't a great fix, and the article (which I'll add later today) also says that Microsoft has NOT set a timeline for fixing it yet."
