Surface Duo 2 and at&t 5G Wireless Whitelist
2021-12-18T22:29:31+00:00
Would there be any information on when at&t will whitelist the Surface Due 2 to enable 5G wireless?
Tom
Surface | Surface Duo | Mobile connectivity
    2022-02-23T15:31:09+00:00
    My SD2 has connected to, and displayed the 5G symbol with AT&T. Using it though was slow. It seemed LTE still provided a faster data experience.
    2022-02-11T08:50:20+00:00
    My Surface Duo USB port crack around it and still under one year warranty however response from Microsoft Support is to contact them. So I contacted them but they are asking for $760 Canadian for shipping the unit for repair. This is a well know deficiency of the frame construction around the USB C-Port and they are well aware of the issue but they simply want to make more money out of their poor case design. The frame around the unit like all other similar cell phones should have been metal. This is my first Microsoft hardware purchase and unfortunately would the last one. I will start posting my comments where ever possible to advise others to stay away from purchase of such poor constructed unit with such high price.
    2022-01-14T17:41:34+00:00
    I have not been able to get the 5G indicator on my SD2. I've been in 5G areas where my wife's iPhone (same plan) gets 5G and I don't. I have a new 5G sim from AT&T.
    2022-01-10T19:18:31+00:00
    Hi Thomas Talley,
    You should be seeing 5G speeds on your Surface Duo 2 on AT&T if you are in an eligible coverage area. Are you not seeing a 5G connection when you should?
