Surface Duo 2 and at&t 5G Wireless Whitelist
2021-12-18T22:29:31+00:00
Would there be any information on when at&t will whitelist the Surface Due 2 to enable 5G wireless?
Tom
Surface | Surface Duo | Mobile connectivity
    2022-03-21T15:03:06+00:00
    AT&T has updated their document to indicate 5G is supported on Surface Duo 2
    Service Capabilities for your Unlocked Device (att.com)
    2022-03-08T16:07:04+00:00
    I've been playing with T-Mobile with a one-month 2.5GB plan.
    • SD2 connects at 5G in more places than AT&T has 5G on my wife's iPhone.
    • It is screamingly fast. I did a speedtest.net test with their app and got like 607mbs down.
    Caution: That test seems to cost 1GB of data.
    I'm ready to switch carriers as soon as I can get the rest of the family on board with moving.
    I am not affiliated with either AT&T or T-Mobile.
    2022-01-06T20:22:01+00:00
    While the Duo 2 supports 5G, at&t needs to allow it. They publish a "whitelist":
    https://www.att.com/idpassets/images/support/wireless/Service-Capabilities-Unlocked-Devices-ATT-Network.pdf The current version dated 15DEC21 shows that at&t has only enabled Duo 2 for only HD Voice and Wi-Fi Calling. You can observe that at&t has enabled 5G for many other phones (i.e., Galaxy S21 FE).
    My Duo 2 does have an at&t 5G sim. The "at&t tech" stated that they only have 5G sims in stock.
    I was hoping that MS would have some "intel" as to when at&t will enable Duo 2 5G on their network.
    2022-01-06T20:07:41+00:00
    Hi Thomas Talley,
    Surface Duo 2 does support 5G on AT&T's wireless network. You may need to contact AT&T to make sure you are using a compatible SIM card.
    Thank you
    2021-12-19T00:27:33+00:00
    This is a volunteer user-to-user help forum. It would be best to contact AT&T and ask them when it will happen.
