Hello @janette_Z - I placed the earbuds back into the charging case and plugged in the charging cable. Charged it for about 20 minutes, and when I tried again, it now works correctly.
For reference:
- May we know the make and model of the smartphone you're using? Google Pixel 4 XL
- What other apps are involved when the issue happens? None, just Phone calls and Microsoft Teams
- Have you tried the earbuds on another host device to see if the same thing happens? Yes, my Surface Laptop (first generation). Same issue.
- Does it happen when you make outgoing calls or does it only happen when receiving calls? Both.
- Earbuds were updated prior to the issue
