Surface Pro 3 Blue Screen due to Wifi?
2014-06-30T17:19:17+00:00
You guys are lucky.  The marvell network adapter is causing a BSOD for me.  I linked some of my memory dumps for MS or anyone interested.
MiniDump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32762&authkey=!ADC7RkR1Ol-EjYU&ithint=file%2c.dmp
Full Memory Dump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32763&authkey=!AOpLL7cw2JTzqk4&ithint=file%2c.DMP
Microsoft (R) Windows Debugger Version 6.3.9600.17029 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff8039b818000 PsLoadedModuleList = 0xfffff8039bae22d0
Debug session time: Fri Jun 27 12:21:18.597 2014 (UTC - 4:00)
System Uptime: 0 days 0:02:39.786
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd00098def340, ffffd00098def298, 0}
*** ERROR: Module load completed but symbols could not be loaded for mrvlpcie8897.sys
*** ERROR: Module load completed but symbols could not be loaded for wificlass.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : mrvlpcie8897.sys ( mrvlpcie8897+18cdb )
Followup: MachineOwner
2014-12-11T00:01:14+00:00
Confirmed by Microsoft:
Solution Task || v-2sack || 08-Dec-2014 12/08/2014 11:12
Symptom:
Machine  (Surface Pro 3) running with "Windows 8.1 Pro" crashes with the bugcheck "0x0000000a (0xfffff6f000cf5000, 0x0000000000000002, 0x0000000000000000, 0xfffff800bc365f66)" after you connected it to the employee network called "XXX"  using CISCO wireless network and it crashed only if the feature Flexconnect (CISCO WIRELESS) was enabled.
Cause:
Cisco wireless Access Points was outdated.
Resolution:
Cisco updated the wireless Access Points to a new version of code which resolved the issue completely.
2014-12-09T13:12:54+00:00
Well after a couple weeks working with Microsoft Commercial Technical Support a situation arose that resolved this issue. Apparently our Cisco support vendor was having the same complaint at another of their customer's site. There was a firmware update for the Cisco 1142 access points. To be specific the version is 7.6.130.0. We applied this update to all of our APs and this fixed the BSOD on all of the Surface Pro 3 devices.
155 additional answers
    2015-01-16T19:12:11+00:00
    Just adding my voice to the list of 'resolved'.
    This AM I installed the updates, confirmed I have the 15.68.3073.151 update and all is good.
    Thanks to all who contributed to tracking this issue to resolution.
    2015-03-03T08:15:06+00:00
    I have the driver 15.68.3073.151 but still continue to experience BSODs on my Surface Pro 3 when switching between networks.
    2015-03-03T14:22:45+00:00
    Did you remember to update the Bluetooth driver with that version as well?  All firmware updates?  Is it the same BSOD as the other Wifi BSODs?
