Surface Pro 3 Blue Screen due to Wifi?
2014-06-30T17:19:17+00:00
You guys are lucky.  The marvell network adapter is causing a BSOD for me.  I linked some of my memory dumps for MS or anyone interested.
MiniDump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32762&authkey=!ADC7RkR1Ol-EjYU&ithint=file%2c.dmp
Full Memory Dump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32763&authkey=!AOpLL7cw2JTzqk4&ithint=file%2c.DMP
Microsoft (R) Windows Debugger Version 6.3.9600.17029 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff8039b818000 PsLoadedModuleList = 0xfffff8039bae22d0
Debug session time: Fri Jun 27 12:21:18.597 2014 (UTC - 4:00)
System Uptime: 0 days 0:02:39.786
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd00098def340, ffffd00098def298, 0}
*** ERROR: Module load completed but symbols could not be loaded for mrvlpcie8897.sys
*** ERROR: Module load completed but symbols could not be loaded for wificlass.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : mrvlpcie8897.sys ( mrvlpcie8897+18cdb )
Followup: MachineOwner
2014-12-11T00:01:14+00:00
Confirmed by Microsoft:
Solution Task || v-2sack || 08-Dec-2014 12/08/2014 11:12
Symptom:
Machine  (Surface Pro 3) running with "Windows 8.1 Pro" crashes with the bugcheck "0x0000000a (0xfffff6f000cf5000, 0x0000000000000002, 0x0000000000000000, 0xfffff800bc365f66)" after you connected it to the employee network called "XXX"  using CISCO wireless network and it crashed only if the feature Flexconnect (CISCO WIRELESS) was enabled.
Cause:
Cisco wireless Access Points was outdated.
Resolution:
Cisco updated the wireless Access Points to a new version of code which resolved the issue completely.
2014-12-09T13:12:54+00:00
Well after a couple weeks working with Microsoft Commercial Technical Support a situation arose that resolved this issue. Apparently our Cisco support vendor was having the same complaint at another of their customer's site. There was a firmware update for the Cisco 1142 access points. To be specific the version is 7.6.130.0. We applied this update to all of our APs and this fixed the BSOD on all of the Surface Pro 3 devices.
155 additional answers
    2014-11-25T22:52:09+00:00
    I have a surface pro 3 and getting constant BSOD with DPC_Watchdog_Violation msg when in office.
    it occurs in the office when have a wired connection or when using our wireless which is Cisco of some variety. BSOD also when have wireless specifically turned OFF while on a wired connectio as well.
    After 3 BSOD in rapid succession at the office, i tried something different...ti did not seem to occur when I used wireless and was connected to my cell phone's Personal Hotspot as the internet connection.  Will test that some more, but it is not a viable "solution"
    Would this be a  wifi issue or other? Suggestion on what and how to look for in a dmp file or other diagnosis process?
    Have loaded the latest updates already.
    thanks in advance for insights. And triple thanks for an outright solution :-)
    Additional info for my BSOD issue, I hope to get suggestions for.
    In the one office building I have had issues in, we do have the Cisco 1142.  However in the other office building we have a Cisco 1242.  Perhaps my BSOD is from another or {groan} multiple issues.
    I do use a pluggable USB 3.0 docking station in both locations and have checked for any software updates.
    Today no BSOD so far while working. Tried these settings:
    Airplane Mode ON
    Wifi ON but not connected
    Wired network connection through Plugable USB 3.0 docking station
    Any help appreciated
    2014-11-25T23:06:37+00:00
    Airplane Mode ON
    Not two minutes after I submitted the above update about no BSOD today, of course it BSOD's on me. So much for airplane mode as a trick to skirt the problem.
    2014-11-26T22:31:31+00:00
    KHW.surfacePro3,
    It looks like you're experiencing a different issue that what's noted in this thread.
    I would suggest pursuing the specific 'DPC_Watchdog_Violation" error message you're receiving.
    Maybe this will help you out and get started down the right path:
    http://www.eightforums.com/bsod-crashes-debugging/17257-bsod-dpc-watchdog-violation.html
