Surface Pro 3 Blue Screen due to Wifi?
2014-06-30T17:19:17+00:00
You guys are lucky.  The marvell network adapter is causing a BSOD for me.  I linked some of my memory dumps for MS or anyone interested.
MiniDump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32762&authkey=!ADC7RkR1Ol-EjYU&ithint=file%2c.dmp
Full Memory Dump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32763&authkey=!AOpLL7cw2JTzqk4&ithint=file%2c.DMP
Microsoft (R) Windows Debugger Version 6.3.9600.17029 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff8039b818000 PsLoadedModuleList = 0xfffff8039bae22d0
Debug session time: Fri Jun 27 12:21:18.597 2014 (UTC - 4:00)
System Uptime: 0 days 0:02:39.786
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd00098def340, ffffd00098def298, 0}
*** ERROR: Module load completed but symbols could not be loaded for mrvlpcie8897.sys
*** ERROR: Module load completed but symbols could not be loaded for wificlass.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : mrvlpcie8897.sys ( mrvlpcie8897+18cdb )
Followup: MachineOwner
2014-12-11T00:01:14+00:00
Confirmed by Microsoft:
Solution Task || v-2sack || 08-Dec-2014 12/08/2014 11:12
Symptom:
Machine  (Surface Pro 3) running with "Windows 8.1 Pro" crashes with the bugcheck "0x0000000a (0xfffff6f000cf5000, 0x0000000000000002, 0x0000000000000000, 0xfffff800bc365f66)" after you connected it to the employee network called "XXX"  using CISCO wireless network and it crashed only if the feature Flexconnect (CISCO WIRELESS) was enabled.
Cause:
Cisco wireless Access Points was outdated.
Resolution:
Cisco updated the wireless Access Points to a new version of code which resolved the issue completely.
2014-12-09T13:12:54+00:00
Well after a couple weeks working with Microsoft Commercial Technical Support a situation arose that resolved this issue. Apparently our Cisco support vendor was having the same complaint at another of their customer's site. There was a firmware update for the Cisco 1142 access points. To be specific the version is 7.6.130.0. We applied this update to all of our APs and this fixed the BSOD on all of the Surface Pro 3 devices.
155 additional answers
    2014-11-21T19:52:27+00:00
    Here is exactly what I found has created the BSOD and how to fix it in our environment. We are using Cisco 1142 wireless APs and turning the FlexConnect feature ON makes the Surface Pro 3 BSOD when they are connecting to the wireless network. With that feature turned OFF they connect and function perfectly fine. PLEASE Microsoft look into this specific area. We confirmed with our Cisco installer that he is having the same issue at a different client's site with the same APs and Surface Pro 3. He is going to test turning off FlexConnect there.
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-11-21T20:05:58+00:00
    Do you have this issue after applying the 11/19 firmware update?
    2014-11-21T20:12:18+00:00
    Yes. I was excited to see there was a firmware update that specifically spoke about Cisco ATAs. I tried 3 devices. All with same results. The same behavior as before.
