Surface Pro 3 Blue Screen due to Wifi?
2014-06-30T17:19:17+00:00
You guys are lucky.  The marvell network adapter is causing a BSOD for me.  I linked some of my memory dumps for MS or anyone interested.
MiniDump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32762&authkey=!ADC7RkR1Ol-EjYU&ithint=file%2c.dmp
Full Memory Dump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32763&authkey=!AOpLL7cw2JTzqk4&ithint=file%2c.DMP
Microsoft (R) Windows Debugger Version 6.3.9600.17029 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff8039b818000 PsLoadedModuleList = 0xfffff8039bae22d0
Debug session time: Fri Jun 27 12:21:18.597 2014 (UTC - 4:00)
System Uptime: 0 days 0:02:39.786
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd00098def340, ffffd00098def298, 0}
*** ERROR: Module load completed but symbols could not be loaded for mrvlpcie8897.sys
*** ERROR: Module load completed but symbols could not be loaded for wificlass.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : mrvlpcie8897.sys ( mrvlpcie8897+18cdb )
Followup: MachineOwner
2014-12-11T00:01:14+00:00
Confirmed by Microsoft:
Solution Task || v-2sack || 08-Dec-2014 12/08/2014 11:12
Symptom:
Machine  (Surface Pro 3) running with "Windows 8.1 Pro" crashes with the bugcheck "0x0000000a (0xfffff6f000cf5000, 0x0000000000000002, 0x0000000000000000, 0xfffff800bc365f66)" after you connected it to the employee network called "XXX"  using CISCO wireless network and it crashed only if the feature Flexconnect (CISCO WIRELESS) was enabled.
Cause:
Cisco wireless Access Points was outdated.
Resolution:
Cisco updated the wireless Access Points to a new version of code which resolved the issue completely.
2014-12-09T13:12:54+00:00
Well after a couple weeks working with Microsoft Commercial Technical Support a situation arose that resolved this issue. Apparently our Cisco support vendor was having the same complaint at another of their customer's site. There was a firmware update for the Cisco 1142 access points. To be specific the version is 7.6.130.0. We applied this update to all of our APs and this fixed the BSOD on all of the Surface Pro 3 devices.
155 additional answers
    2014-10-14T19:59:40+00:00
    same happens for me, after wake up from hibernation ( not sleep as I have Hyper-V installed) Wifi can't connect and next thing which it does is a blue screen with wificlass.sys
    any solution Microsoft?
    Having so many problem with wifi on this device that I can't imagine u want to people actually work on it, instead of play or watch movies.
  2. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2014-10-15T11:15:54+00:00
    As you probably know, there were no WiFi fixes for yesterday's patch Tuesday,
    just some marketing message about updates in "the coming weeks". I don't
    honestly know if or when these issues will be addressed. I can only recommend
    (as I've done before)
    http://digitalmediaphile.com/index.php/2014/09/21/a-40-fix-for-surface-pro-3-slow-wifi/
    • as a fix for both of your issues. It's lousy that people need to throw money
    at a situation that Microsoft should fast track solutions for, but for me, the
    SP3 would be unusable outside my home without this "solution".
    Barb
    2014-10-15T15:33:22+00:00
    All of my wificlass BSODs have all been fixed by wiping out my surface pro 3 and reloading it after the latest firmware update. Not one BSOD since. All of my software has been reinstalled for at least two weeks and I haven't had a single issue.
    Not suggesting that you HAVE to go out and do a wipe, but so far so good for me.
