Surface Pro 3 Blue Screen due to Wifi?
2014-06-30T17:19:17+00:00
You guys are lucky.  The marvell network adapter is causing a BSOD for me.  I linked some of my memory dumps for MS or anyone interested.
MiniDump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32762&authkey=!ADC7RkR1Ol-EjYU&ithint=file%2c.dmp
Full Memory Dump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32763&authkey=!AOpLL7cw2JTzqk4&ithint=file%2c.DMP
Microsoft (R) Windows Debugger Version 6.3.9600.17029 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff8039b818000 PsLoadedModuleList = 0xfffff8039bae22d0
Debug session time: Fri Jun 27 12:21:18.597 2014 (UTC - 4:00)
System Uptime: 0 days 0:02:39.786
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd00098def340, ffffd00098def298, 0}
*** ERROR: Module load completed but symbols could not be loaded for mrvlpcie8897.sys
*** ERROR: Module load completed but symbols could not be loaded for wificlass.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : mrvlpcie8897.sys ( mrvlpcie8897+18cdb )
Followup: MachineOwner
2014-12-11T00:01:14+00:00
Confirmed by Microsoft:
Solution Task || v-2sack || 08-Dec-2014 12/08/2014 11:12
Symptom:
Machine  (Surface Pro 3) running with "Windows 8.1 Pro" crashes with the bugcheck "0x0000000a (0xfffff6f000cf5000, 0x0000000000000002, 0x0000000000000000, 0xfffff800bc365f66)" after you connected it to the employee network called "XXX"  using CISCO wireless network and it crashed only if the feature Flexconnect (CISCO WIRELESS) was enabled.
Cause:
Cisco wireless Access Points was outdated.
Resolution:
Cisco updated the wireless Access Points to a new version of code which resolved the issue completely.
2014-12-09T13:12:54+00:00
Well after a couple weeks working with Microsoft Commercial Technical Support a situation arose that resolved this issue. Apparently our Cisco support vendor was having the same complaint at another of their customer's site. There was a firmware update for the Cisco 1142 access points. To be specific the version is 7.6.130.0. We applied this update to all of our APs and this fixed the BSOD on all of the Surface Pro 3 devices.
155 additional answers
    2014-09-30T03:41:39+00:00
    Hi Martin,
    i know how you feel! I had the same issue, what helped for me was to reset the surface to factory settings, perform all updates (bear in mind, you need to install a series of them, but if you install the first set you might have to wait before it finds the other update) and then install stuff like office and so on. Did that 2 weeks ago, it is now running smoothly.
    regards,
    Ruud
    2014-09-30T03:54:04+00:00
    I am not going to nuke the machine and start over.  Sooner or later Microsoft will fix this problem  Surface Pro 3 i7 crashes with wificlass.sys SYSTEM_THREAD_EXCEPTION_NOT_HANDLED.  If MartinFL just got his and it is doing it then in effect he started with a clean machine, assuming he ran all the updates.  Microsoft blew it bigtime and if they cant fix it then they should not be in the hardware business, which is hard for me to say because I have said they should be in the hardware business for 20+ years.  They need new management to replace those currently responsible.
    2014-09-30T09:11:43+00:00
    Ruud,
    Thanks for suggestion. Yes, I should be all up-to-date when it comes to drivers and updates. I just find it so hard to bring myself to reset everything back to factory settings after wasting two full work days setting up my system and development environment.
    However, I think found a workaround that seems to work for me:
    1. Download "Surface Pro - September 2014.zip" drivers pack from http://www.microsoft.com/en-us/download/details.aspx?id=38826
    2. Extract "Surface Pro - September 2014.zip" somewhere.
    3. Open Device Manager, uninstall "Marvell AVASTAR Wireless AC Network Controller", until it is completely gone and let it remove whatever Wifi drivers are currently installed.
    4. In Device Manager, right-click "Network adapters" and scan for hardware changes. You should now see an item "Unknown device" (or something similar)
    5. Right-Click the "Unknown Device", and install the driver from "Surface Pro - September 2014\Marvell\wlan"
    Done.
    My system still can't find the network when it wakes up (I must manually turn the Wifi off and back on in order to reconnect), but at least I no longer get the BSOD (wificlass.sys SYSTEM_THREAD_EXCEPTION_NOT_HANDLED), which is a HUGE plus. I can live with this for the time being, until MS finally provides us with drivers that actually work.
    I hope this helps :)
