Surface Pro 3 Blue Screen due to Wifi?
2014-06-30T17:19:17+00:00
You guys are lucky.  The marvell network adapter is causing a BSOD for me.  I linked some of my memory dumps for MS or anyone interested.
MiniDump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32762&authkey=!ADC7RkR1Ol-EjYU&ithint=file%2c.dmp
Full Memory Dump
https://onedrive.live.com/redir?resid=63F5D6A6AB9AA87E!32763&authkey=!AOpLL7cw2JTzqk4&ithint=file%2c.DMP
Microsoft (R) Windows Debugger Version 6.3.9600.17029 AMD64
Copyright (c) Microsoft Corporation. All rights reserved.
Loading Dump File [C:\Windows\MEMORY.DMP]
Kernel Bitmap Dump File: Only kernel address space is available
************* Symbol Path validation summary **************
Response                         Time (ms)     Location
Deferred                                       SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Symbol search path is: SRV*c:\symbols*http://msdl.microsoft.com/download/symbols
Executable search path is:
Windows 8 Kernel Version 9600 MP (4 procs) Free x64
Product: WinNt, suite: TerminalServer SingleUserTS
Built by: 9600.17085.amd64fre.winblue_gdr.140330-1035
Machine Name:
Kernel base = 0xfffff8039b818000 PsLoadedModuleList = 0xfffff8039bae22d0
Debug session time: Fri Jun 27 12:21:18.597 2014 (UTC - 4:00)
System Uptime: 0 days 0:02:39.786
Loading Kernel Symbols
Loading User Symbols
Loading unloaded module list
*                        Bugcheck Analysis                                    *
Use !analyze -v to get detailed debugging information.
BugCheck 139, {3, ffffd00098def340, ffffd00098def298, 0}
*** ERROR: Module load completed but symbols could not be loaded for mrvlpcie8897.sys
*** ERROR: Module load completed but symbols could not be loaded for wificlass.sys
*** WARNING: Unable to verify timestamp for win32k.sys
*** ERROR: Module load completed but symbols could not be loaded for win32k.sys
Probably caused by : mrvlpcie8897.sys ( mrvlpcie8897+18cdb )
Followup: MachineOwner
2014-12-11T00:01:14+00:00
Confirmed by Microsoft:
Solution Task || v-2sack || 08-Dec-2014 12/08/2014 11:12
Symptom:
Machine  (Surface Pro 3) running with "Windows 8.1 Pro" crashes with the bugcheck "0x0000000a (0xfffff6f000cf5000, 0x0000000000000002, 0x0000000000000000, 0xfffff800bc365f66)" after you connected it to the employee network called "XXX"  using CISCO wireless network and it crashed only if the feature Flexconnect (CISCO WIRELESS) was enabled.
Cause:
Cisco wireless Access Points was outdated.
Resolution:
Cisco updated the wireless Access Points to a new version of code which resolved the issue completely.
2014-12-09T13:12:54+00:00
Well after a couple weeks working with Microsoft Commercial Technical Support a situation arose that resolved this issue. Apparently our Cisco support vendor was having the same complaint at another of their customer's site. There was a firmware update for the Cisco 1142 access points. To be specific the version is 7.6.130.0. We applied this update to all of our APs and this fixed the BSOD on all of the Surface Pro 3 devices.
155 additional answers
    2014-07-10T16:55:37+00:00
    Me too....
    I restored my Surface Pro 3 to factory, installed all updates, and it is still happening. I have a $1400 clipboard basically.
    I'm currently waiting to hear back from a Microsoft Service Manager who is contacting the enterprise engineering team.
    While I wait to hear back I'm currently doing the following:  I uninstalled Symantec Endpoint.  Also under wireless properties for my work network I disabled/unchecked the setting "Look for other wireless networks while connected to this network setting"
    So far it's been fine today but I need to give it a few more days before I see a connection between this and the driver.  I hope it's not Symantec though.  They are pretty bad at support, but I don't think it's there because I have Endpoint install in over 600 machines and servers without issues.
    2014-07-10T23:19:29+00:00
    Excuse me if I'm wrong but that should be unchecked unless you are in a situation where you are constantly moving between different routers and you want your Pro 3 to switch automatically. Even if you have it unchecked, as soon as your Pro 3 gets disconnected it will automatically search and connect to the next available AP if you have it configured to access that AP.
    2014-07-11T00:39:16+00:00
    No you're probably right it should be unchecked except I had a group policy that had it set to enable.  So I removed that this morning and I worked four straight hours today without one BSOD. I put it through a heavy workload and I wasn't in a fixed room either.  That is by far the longest I have gone without one at work.
    My theory behind that setting is that while connected to our work network which uses WPA2- Enterprise it would scan for other networks.  These other networks use WPA2-Personal and a few that are public are open.  I think while connected to a WPA2-Enterprise network the driver bugs out when searching for these other networks.  I came to this conclusion based on my experience with a Surface Pro 3 that came right out of the box.  During OOBE is crashed when it searched for networks.  So I saw that setting and thought it might help.
    Tomorrow I will reinstall Symantec Endpoint and try that out.  If I get no BSOD by mid day Monday.  I will deploy an image to our other Surface Pro 3 and take it from there.
