NEED HELP - EXCHANGE ACTIVESYNC (EAS) will not connect to Exchange Server
2012-10-28T22:11:06+00:00
We have two Surface RT machines.  Neither will connect to our 2003 Exchange Server with the Exchange ActiveSync setup (EAS) option in Mail.  We have lots of other Smartphones and tablets connected.  After many hours, Microsoft Surface Technical Support has not been able to resolve.
Errors received:
  1. "Unable to connect. Ensure the information entered is correct"
  2. A brief error message in the upper right corner of the screen that says ******@myOUTSIDEdomain.com is unavailable
Data Entered:
Using: Mail Tile/add your mail accounts/view all in set.../Other Account/Exchange ActiveSync (EAS)/show more details setup screen:
  1. Email address: ******@myOUTSIDEdomain.com
  2. Server address: webmail.myOUTSIDEdomain.com
  3. Domain: myINSIDEdomain
  4. Username: johnsmith
  5. Password: mypassword
Please let me know if you see something wrong with the above data - it works for about 40 other mobile device.
Surface | Other
2012-11-05T19:50:10+00:00
Wow, there is a lot of misinformation on this board..... Surface does connect to Exchange and has since day 1. The problem is that you are using self signed certificates, and surface does not accept self signed certificates unless you install them yourself. This is done for security, it had nothing to do with joining domains or anything like that, there is no bug. Exchange mail has worked on my surface since October 26th. Make sure you install the cert under
"Trusted Root Certification Authorities"
http://www.lonecpluspluscoder.com/2012/10/how-to-make-a-self-signed-ssl-certificate-work-with-windows-rts-mail-app-on-a-microsoft-surface-rt/
http://blog.brightpointuk.co.uk/adding-exchange-email-account-windows-rt
68 additional answers
    2012-11-04T23:40:51+00:00
    We're using Exchange 2010 right now, and we can access corporate email, contacts, calendar via....
    1. BB - Of course that's through BES
    2. BB Playbook via Activesync, not BES
    3. iPhone via AS
    4. iPad via AS
    5. Android - using Touchdown pre 4.0, native 4.0 and above
    Since everything except 1 is via MICROSOFT's ActiveSync, then expecting an iPad (not PC) -like Tablet (i.e. Surface) should work.
    Having said all that, you are right, we have not rolled Win8 out yet, so maybe we are not Win8 friendly just yet.
    That's the nuance - I'm still looking for a spec difference... although the Windows 8 Mail client uses ActiveSync protocol, I don't believe it works like a mobile device. It's hybridized - and it also seems to depend a little whether your Surface account is local only or linked to live.com
    I'm curious about this now, so I'm going to do some more digging. If I can find something conclusive I'll post here. In the interim if you are able to talk to IT re: Windows 8 in general or having them look at the ActiveSync logs to see what happens when you Surface attempts to connect, I would love to know what they see.
    2012-11-04T23:30:25+00:00
    Think of it this way...
    If you have a home computer (prior to windows 8), how do you get work e-mails? Only two ways:
    1. You visit your company's webmail page and login. In this case you can only access content through the browser, and there is a restriction as to whether you can download attachments and how long you session lasts before you have to login again.
    2. You create a VPN tunnel, which in and of itself requires the installation of corporate SW on your home PC (usually this is banned even though employees typically ignore this policy), then you have to login, which also usually enforces specific policies (anti-virus SW, split-tunneling, etc). Then you need an e-mail client like Outlook to connect to your server, which also requires strong authentication (username, domain, and AD password).
    If you tried to use Outlook on your home PC to connect to your mail server the same way you have your mobile device configured, it won't work. Hand-in-hand with that when using Outlook to get your corporate mail you aren't forced to set passwords for your PC and make your computer open to remote wipes because you have to already be on the corporate network (via VPN) to see the Exchange server.
    On Windows 8 Pro, you get a message when connecting to Exchange for the first time when using the Metro Mail app that you have to accept policies on your home computer that relate to password requirements, screen timeout, and type of login. The surface does the same thing.
    I would be curious whether a Windows 8 Pro computer (forget about whether it's a Surface Pro or a regular PC simply upgraded to Windows 8) has the same problem with your company. I suspect it does, and I suspect it is because your company either is using an older Exchange server platform that doesn't know how to handle Windows Mail clients or the Exchange policy your company has setup is not "Windows 8 friendly". A good test would be to take a Windows 8 computer outside your company's network and NOT a part of you're company's AD domain, and configure the Mail app. If you get the same error, the issue is not Surface or Windows RT but in fact your company's policy. If this is the case and your company does not want to change their policy, the two options above (web client or VPN + Outlook) are the only ways a PC can access e-mail. The Surface, as a PC and NOT a mobile device, would have the same limitation.
    I know this is long winded but I hope it makes sense.
    3. iPhone via AS
    4. iPad via AS
    2012-11-04T22:46:52+00:00
    My point is that saying that a Surface is between a PC and Mobile Device is not an excuse for this not to work. If Windows Phone or an iPad can access my exchange servers, I'm expecting my Surface to do the same. I don't think it's a big ask.
    If these are bugs, I'm fine with that. However, I fear that there are indeed policies missing from this OS that will not allow me to use it. And so it's sad that a phone or iPad is secure enough for business but the surface is not.
    Cheers
    2012-11-04T22:21:56+00:00
    Yes, sounds like I got the wrong end of the sparkler.  :-)
    I totally agree with what you're saying and have my fingers crossed that MS sort out these issues sooner rather than later... although my email is working my 'push' configuration is less than reliable.
    I guess its too much to ask for an acknowledged bug list from MS as this may damage sales?
