Mine gets hot every so often after charging overnight and I must do a hold-down power reboot.
Overheating issue in the new Surface Pro 8: getting even hotter when charger is connected
I have purchased a brand new Surface Pro 8 from Microsoft website, it has 16GB RAM and 1TB SSD in USA. Since when I purchased it, I am having some hitting issue. After only half an hour of regular usage, the Surface is becoming hotter. An more importantly, overheating is happening when the charger (official charger that came with it) is connected. Initially I felt it by touching with hand. Later, I have checked the core temperatures using Core Temp 1.17.1 (a free software). When the charger is not connected, the temperature is remaining around 45 degree C, sometimes a bit higher and lower than that. While this itself was to a bit hotter side, the temperature increased an became around 50 to 55 degree C when I connected the charger, and that happened just after five minutes of connecting the charger with regular use like YouTube video playing, web browsing in 10-15 tabs. Even sometimes I saw more than 60 degree C when the charger is connected.
I spent around 2500 USD for this device, and feeling unlucky in seeing such heating issue in a high-end latest device by Microsoft. Any solution from experienced people and Microsoft is highly appreciated.
Zobaer Islam
>>Edited post to remove PII
2022-09-17T16:58:24+00:00 -
Deleted
2022-09-24T12:22:54+00:00 Thanks for this trick. I'll try.
2022-09-24T15:23:40+00:00 Thanks. Seems to work for me as well.
2022-11-25T20:37:33+00:00 Sorry but could you please tell me what you did to solve your problem?
