constant PFN_LIST_CORRUPT BSOD on surface pro 7
2020-11-19T08:47:16+00:00
I have a surface pro 7 that I use 90% of the time for taking notes. I've noticed that about once every week, immediately after using the camera in Onenote for Windows 10 I get a PFN_LIST_CORRUPT blue screen. This happens when onenote is syncing with onedrive, after the camera app has shut down. This doesn't occur every time I use the camera, and so far I have only seen this BSOD while using onenote. My four most recent minidump files can be found here: https://1drv.ms/u/s!AmXBsokKEXVkwBl\_KnsTW9XEo91w
Any solutions?
    2021-05-26T19:06:14+00:00
    Mine is 1866. Mostly have issues with front cam. Just because I do not use rear one. The issue appears in Zoom, Skype and other meeting apps
    2021-05-26T19:12:40+00:00
    Let’s sue them! People received $500 million from Apple for battery issues with 6 and 7 iPhone.
    They sell faulty device and refuse to fix issues it has. I have Pro5 at work which is free of any such issues. I am gonna check the camera device make/model on it to compare. Will keep you posted
    2021-05-26T20:01:47+00:00
    1866 is the model number, not the LOT number (all Pro 7 i5 8GB 128GB models are model 1866). The LOT number is on the same sticker on the underside of your box, but a bit further down and a little smaller. It says LOT: XXXX with XXXX being the LOT number.
    2021-05-26T20:04:10+00:00
    I'd love to sue them, but it's not so easy to get a lot of money by suing companies here in Europe. However, if you got 500 Million by suing Microsoft, I'd appreciate it if you gave me $1000 of them so I can buy a Pro 7+ or an iPad + Laptop instead ;)
    2021-05-27T21:20:29+00:00
    Okay, so I received my next replacement device today, and not only does it have a couple of quality issues (camera, build quality) and a battery that has 139 cycles completed, but it also suffers from the exact same BSOD issue. I will try to get it replaced with something better now.
