Nope, but I've found that it happens more often with Windows 11, maybe it occurs more often when more of the RAM/CPU is used.
constant PFN_LIST_CORRUPT BSOD on surface pro 7
I have a surface pro 7 that I use 90% of the time for taking notes. I've noticed that about once every week, immediately after using the camera in Onenote for Windows 10 I get a PFN_LIST_CORRUPT blue screen. This happens when onenote is syncing with onedrive, after the camera app has shut down. This doesn't occur every time I use the camera, and so far I have only seen this BSOD while using onenote. My four most recent minidump files can be found here: https://1drv.ms/u/s!AmXBsokKEXVkwBl\_KnsTW9XEo91w
Any solutions?
2022-04-11T14:39:54+00:00 -
2022-04-12T18:15:03+00:00 Hi. I just ordered a surface pro 7 today, and I stumbled upon these articles. Should I cancel my order?
2022-04-12T18:56:12+00:00 Since you probably have a free return window, I'd first try it and return it if you have the same problem. It seems that there are also people whose Pro 7 works just fine, I just don't know why it has this bug for some.
However, keeping it if it works might still pose a risk as this particular bug can't really be forced, it happens sometimes but not every time you use the rear camera, so you just have to assess your risk taking individually.
(Also maybe consider the Pro 7+ or Pro 8 as those are better in some aspects, but of course they cost more, too)
2022-04-12T19:18:27+00:00 Fun fact: I found the Pro 8 cheaper with $100! But, I'm thinking of buying an apple device, since I've had exelent reliablity from them.
2022-04-12T19:21:16+00:00 I totally agree with Ja_Mo! You’d better choose another product. Try Pro6 or Pro8 or even better buy Mi Pad :))
My device still have this glitches from time to time however it seems that this has become less frequent
