Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-27T20:47:32+00:00
    I did see some talk of RTM 1903 mentioned and it is "supposed" to be released this month.  This month is almost over with, so keep an eye out on Windows Update (not unless Microsoft delayed the release).
    2019-09-27T20:17:28+00:00
    ok, I tried your solution and, yes it improve the battery performance: after SMT disabling and the battery calibration (one cycle of complete discharge and one of full charge), in one hours only the 23% of discharge (from 100%).
    Thanks for your suggestion
    However, it could be only a temporary solution in waiting for an update to fix the August update troubles.
    2019-09-27T18:50:11+00:00
    The code name for 19H1.  Thanks Barb.
  4. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-27T18:45:11+00:00
