Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-27T17:33:36+00:00
    Any news for Surface-series firmware update from MS?
    2019-09-27T17:28:36+00:00
    Well, mine updated and no Firmware update came across!  Nobody waved a magic wand and updated the firmware to a newer version.  No Accumulative update came across either - only the Windows Insider Build and the Windows Defender descriptor file.  Nothing else came across.
  3. Barb Bowman 80,805 Reputation points MVP Volunteer Moderator
    2019-09-27T17:26:59+00:00
    Please see
    https://answers.microsoft.com/message/8b4da01e-c98f-4102-a879-a6e43dd46079?threadId=9cd4c436-a23c-46c8-b595-616ce6561004
    Jason Howard from the Windows Insider team has addressed whether firmware is
    baked into Insider Builds. (For the same reason, it would not be baked into
    Cumulative Updates.)
    2019-09-27T17:15:57+00:00
    The Firmware is built into the build itself.  If not, it would show on the list and as you can see, it is NOT on the list!  No Firmware update came across to upgrade it - just the build.
    ... is apparently resolved by firmware currently being distributed via Windows Insider.
    OS preview builds do not contain Surface firmware updates.  This would unnecessarily push Surface FW to every device across the planet installing the OS.
    It's possible that a FW preview was marked to be released to users on a specific build number or higher, but we don't track Surface FW releases as part of the WIP program which is of course focused on the OS preview builds.
