Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-25T10:27:49+00:00
    Well, thanks for the suggestion, but it didn't work for me.
    2019-09-24T23:00:31+00:00
    Okay, I'll give that a try. I had turned off hibernate, that is, set it so that it never happens, but I hadn't actually disabled the function. I'll see what happens now.
    2019-09-24T21:36:12+00:00
    This is how I disabled it
    From an administrator command prompt:
    powercfg.exe /hibernate off
    I've tried multiple things from this thread and this is the only thing that has worked for me (so far).
    2019-09-24T21:03:50+00:00
    How specifically did you disable hibernation, because as far as I know, I’ve had it disabled this whole time.
    Not to be pessimistic, but it seems that a number of people, including myself, have declared the problem “fixed” only to return and say that it’s back within a couple of days.
