Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-22T11:59:31+00:00
    Surface laptop (1st gen) Win10 1803 here:
    I followed the steps for the insider preview, updated to 1909, and after testing found the 75% bug still present.
    So I rolled back to 1803.
    There are no new firmware updates for the surface laptops atm, so I would wait until there is a new firmware update for a true fix. (mine is on 137.2706.768.0 - you can check yours by going to control panel, then 'system information')
    My solution was to switch off hibernation:
    command prompt, type powercfg.exe /hibernate off
    I can now shutdown and switch on like before and it works like when I first got it.
    Good battery life and the percentage stays the same overnight unplugged.
    Obviously it breaks hibernation, but hopefully when a new firmware is released to fix the battery bug, you can reactivate hibernation by going
    command prompt, type powercfg.exe /hibernate on
    For reference: i could not see any firmware update on the update, it was only “1909 release” single voice. And I got not firmware installation on the booting. Maybe try to uninstall the battery driver? Could be a point
    2019-09-22T10:52:43+00:00
    2019-09-22T07:10:52+00:00
    I uninstalled them and realized there was the box to cancel the drivers after having pressed ok... redid it just in case
    Btw after posting the first post I did some playing with Geforce Now and right now (1 hour I guess?) i'm at 89%
    So seems all good an fine
    2019-09-22T06:48:14+00:00
    Why did you uninstall the drivers again? How did you cancel?
