Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-16T10:24:56+00:00
    I made a new observation last night into this morning.
    Last night, I shut down my PC as usual, but rather than unplug it I left it plugged in for about 30 minutes before putting it away for the night. When I started it up this morning it was 99% charged.
    This further confirms that the apparent 25% power loss is not something that occurs gradually while the device is off but rather occurs immediately upon shutdown.
    I don't see how the battery could actually lose 25% of its power in an instant upon shutdown, but I also don't understand how if it's just the firmware misreading the charge every indication is that it's accurate, as charging appears to occur when it's connected to power, it will die sooner if not charged back to 100%, and as far as I can tell this loss and gain of about 25% each day is counting towards my battery cycles, thereby shortening the lifespan of the battery.
    2019-09-15T19:21:52+00:00
    I am having the same problem.  Just wanted to comment on this thread so I can stay up to date with the latest information and (hopefully) find out when there's finally a fix.
    2019-09-15T15:18:49+00:00
    Be sure to report on the Feedback Hub.
    Please upvote other reports such as mine to ensure that MS takes this issue seriously: https://aka.ms/AA5w24b
    2019-09-15T14:12:03+00:00
    I have the Same Surface Pro 6. Exactly the same issue.
