Battery drain overnight while shutdown
2019-08-17T15:39:13+00:00
Lately, after I shutdown (full shutdown, not sleep or hibernate) my fully charged Surface Laptop 2 at night, I turn it on in the morning and find that the battery has lost around 25% power overnight! What's going on and how can I fix this?
The laptop is only about 6 months old and the battery seems to be in good health.
I've reported this on the MS Feedback Hub. Please upvote it so that it gains attention: https://aka.ms/AA5w24b
Also be sure to report there as well if you are experiencing this issue.
Surface | Surface Laptop | Power and battery
2019-10-11T17:10:26+00:00
Please see https://support.microsoft.com/en-us/help/4469839/surface-laptop-2-update-history
This should be available on Windows Update:
October 10 release
The following updates are available for all Surface Laptop 2 devices running Windows 10 April 2018 Update, version 1803 or greater:
Windows Update History Name Device Manager Name
Surface – Firmware – 145.501.139.0 Surface System Aggregator– Firmware<br><br><ul><br><li><span>145.501.139.0 helps improve battery life.</span></li></ul>
379 additional answers
    2019-09-02T13:07:29+00:00
    Maybe they've already released this fix.
    I don't want to get my hopes up (nor yours) prematurely, but I haven't experienced any power loss during my last couple of shut downs, and I did install an update the other day that I believe was released on August 30th.
    2019-09-02T12:47:14+00:00
    Hi all, I've the same issue, tho it's a Surface Laptop 2. Just to update you all as kind act, I just ended a conversation with MS support and their tech guy stated that this is a problem known to them and they will release soon a fix for it.
    No specified date but "since this is a issue a lot of people is experiencing, the release will be done quite quickly"
    Crossing fingers!
    2019-09-02T08:30:28+00:00
    That's good to know!
    If the problem occurs in the replacement device I receive, I shall try the same trick.
    2019-09-02T08:26:08+00:00
    Yes I did. But no specific response to what might be causing the problem. They just said that we need to isolate the problem and that I should send the device back.
