I am having the same issue!
Here is a quick rundown of my problem.
7/6/19 I bought a Surface Pro 6 i7 1TB. This device turned out to have a defective screen so I took it in for a replacement on 7/27.
7/27/19 I am assigned (what I later discovered was a refurbished unit) a replacement unit. A few days after that I started to notice that when I leave it at 100% at night, unplug it, go to bed, and when I wake up in the morning it would only have 74% o 75%
battery left! Also when it is 100% and I unplug it, take it with me to work, by the time I reach my office about 45 minutes later then turn it on it only has 74 to 75% battery left! I was able to observe this multiple times. I tried several troubleshooting
steps to no success. I am not using hello cortana face unlock or anything fancy.
8/15/19 I went to a Microsoft Store to ask them to take a look at the battery drain issue, and they said they saw nothing wrong and suggested I factory reset the unit which I did when I got home! But the following day the same issue appeared!
8/16/19 I went back to the Microsoft Store and told them the issue has not gone away. They issued me a brand new Surface replacement. At last I thought that was the end of the issue. I left the unit charging overnight, and this morning it was showing 100%.
Out of curiosity I wanted to find out if this unit would have the same issue so I turned off the device at 100%, unplugged it, then left it for a couple of hours. When I turned it back on the battery was showing 74%!!
At this point I don't even know what to do. If anyone has a solution to this problem please share, otherwise I have no choice but to make another trip to the Microsoft Store for a possible fourth replacement.
Here is the drop observed this morning -
| 08:11:51 |
Suspended |
100 % |
47,150 mWh |
| 10:13:56 |
Connected standby |
AC |
74 % |
34,960 mWh |
My entire battery report is below:
| 2019-08-16 <br>14:45:56 |
Active |
Battery |
47 % |
22,420 mWh |
| 14:49:23 |
Connected standby |
Battery |
46 % |
21,840 mWh |
| 14:49:23 |
Suspended |
46 % |
21,840 mWh |
| 16:22:26 |
Connected standby |
Battery |
46 % |
21,790 mWh |
| 16:22:26 |
Active |
Battery |
46 % |
21,790 mWh |
| 16:22:26 |
Active |
AC |
46 % |
21,790 mWh |
| 16:31:39 |
Active |
Battery |
50 % |
23,960 mWh |
| 16:31:51 |
Connected standby |
Battery |
50 % |
23,910 mWh |
| 16:32:52 |
Connected standby |
AC |
50 % |
23,870 mWh |
| 16:33:09 |
Active |
AC |
50 % |
23,950 mWh |
| 17:11:21 |
Active |
Battery |
70 % |
33,260 mWh |
| 17:12:11 |
Active |
AC |
69 % |
33,080 mWh |
| 19:42:15 |
Active |
Battery |
100 % |
47,690 mWh |
| 19:42:21 |
Connected standby |
Battery |
103 % |
49,200 mWh |
| 19:43:04 |
Connected standby |
AC |
103 % |
49,200 mWh |
| 19:43:18 |
Suspended |
103 % |
49,200 mWh |
| 19:47:02 |
Active |
AC |
100 % |
49,200 mWh |
| 20:22:00 |
Suspended |
100 % |
49,200 mWh |
| 20:26:51 |
Active |
AC |
100 % |
49,200 mWh |
| 2019-08-17 <br>07:52:00 |
Suspended |
96 % |
47,150 mWh |
| 07:57:23 |
Active |
AC |
100 % |
47,150 mWh |
| 07:57:23 |
Suspended |
100 % |
47,150 mWh |
| 07:58:28 |
Active |
AC |
100 % |
47,150 mWh |
| 08:04:00 |
Suspended |
100 % |
47,150 mWh |
| 08:07:48 |
Active |
AC |
100 % |
47,150 mWh |
| 08:11:51 |
Connected standby |
AC |
100 % |
47,150 mWh |
| 08:11:51 |
Suspended |
100 % |
47,150 mWh |
| 10:13:56 |
Connected standby |
AC |
74 % |
34,960 mWh |
| 10:13:56 |
Connected standby |
Battery |
74 % |
34,960 mWh |
| 10:13:56 |
Active |
Battery |
74 % |
34,960 mWh |
| 10:13:56 |
Active |
AC |
74 % |
34,960 mWh |
| 10:13:56 |
Active |
Battery |
74 % |
34,960 mWh |
| 10:14:18 |
Active |
AC |
74 % |
34,850 mWh |
| 10:16:26 |
Report generated |
AC |
75 % |
35,130 mWh |
