Surface Pro 2 system issues
2018-07-18T17:10:07+00:00
I am running a Surface Pro 2 with build 17134.167.  There is an external USB HUB with a Dell monitor, mouse and audio connected to the HUB.  After the last 1803 update, the display driver fails to load and the external display is not recognized, although it works.  The Control Panel Device Manager also shows that the unit is not recognized as a Surface model with the keyboard and unit displaying caution icons.  Associated drivers imply that they are for a Surface Pro 4.  The system appears to work, but it has issues.  All updates have been through automatic updates, so I do not understand the Surface Pro 4 designations.
I have tried to update drivers when allowed and that fails with the system telling me that the installed drivers are up to date.
Am I doomed to perform a reinstall, or is there another solution.  Evidentially I have no recovery files, although I am sure that I made some.
    2018-07-24T17:29:03+00:00
    can't unpack the .cab files for the Surface Pro 2
    Explain please.  If you have a .cab file you could use the expand utility to open it.
    something terminating the installation of the SurfaceProUEFI.inf file.
    ProcMon could give you some clues about that.
    The Registry HKEY_LOCAL_HARDWARE DESCRIPTION /SYSTEM /SYSTEMBIOSVERSION .
    OEMA - 1072009
    2.05.0250
    American Megatrends - 4028E
    The Panther files will be associated with your last cumulative update.
    Setupact.log contains this
    2018-07-10 16:02:56, Info                  SP     Host system information:
                                       VM: NO
                                       Firmware type: UEFI
                                       Manufacturer: Microsoft Corporation
                                       Model : Surface Pro 2
                                       BIOS name : 2.05.0250
                                       BIOS version : 2.05.0250
                                       BIOS release date : 20150410000000.000000+000
                                       Total memory : 8589934592
                                       Number of physical CPUs : 1
                                       Number of logical CPUs : 4
                                       Processor manufacturer : GenuineIntel
                                       Processor name : Intel(R) Core(TM) i5-4300U CPU @ 1.90GHz
                                       Processor caption : Intel64 Family 6 Model 69 Stepping 1
                                       Processor architecture : x64
                                       Processor clock : 2501
    BTW are you sure that you didn't get an SP4 as a replacement for your original SP2?  That would be a simple explanation for your peculiar symptoms.   ; )
    2018-07-24T19:32:36+00:00
    My Setupack.log is nothing like yours.  Multiple instances of the following with different time stamps in close succession:
    2018-07-18 11:35:33, Info                         SystemSettings::DataModel::CRestorePCSettings::CRestorePCSettings Initializing...
    2018-07-18 11:35:33, Info                         SystemSettings::DataModel::CRestorePCSettings::GetActionDescription - Settings Item being displayed: SystemSettings_Misc_ResetYourPCActionDescription, Return: 0
    2018-07-18 11:35:33, Info                         SystemSettings::DataModel::CRestorePCSettings::get_IsEnabled - Settings Item Enabled:1 for for SystemSettings_Misc_ResetYourPCActionDescription
    2018-07-18 11:35:33, Info                         SystemSettings::DataModel::CRestorePCSettings::GetActionDescription - Settings Item being displayed: SystemSettings_Misc_RollbackYourPC_PreviewBuildActionDescription, Return: 0
    2018-07-18 11:35:33, Info                         SystemSettings::DataModel::CRestorePCSettings::get_IsEnabled - Settings Item Enabled:1 for for SystemSettings_Misc_RollbackYourPC_PreviewBuildActionDescription
    2018-07-18 11:35:43, Info                         SystemSettings::DataModel::CRestorePCSettings::get_IsEnabled - Settings Item Enabled:1 for for SystemSettings_Misc_RollbackYourPC_PreviewBuildActionDescription
    2018-07-18 11:35:44, Info                         SystemSettings::DataModel::CRestorePCSettings::Invoke - Settings Item Action Invoked for SystemSettings_Misc_RollbackYourPC_PreviewBuildActionDescription: hresult 0
    2018-07-18 11:35:44, Info                         SystemSettings::AdminFlowUI::UninstallViewModel::UninstallViewModel Uninstall ( via Settings ) Initialized.
    2018-07-18 11:35:44, Info                         SystemSettings::AdminFlowUI::UninstallViewModel::Initialize User is attempting to Uninstall, by clicking Get Started button
    2018-07-18 11:35:44, Warning                      SystemSettings::AdminFlowUI::UninstallViewModel::Initialize UninstallGetInterface Failed with Error: 0x80070490
    2018-07-18 11:35:51, Info                         SystemSettings::AdminFlowUI::UninstallViewModel::~UninstallViewModelUninstall ( via Settings ) Terminated.
    My SP2 is the one I've always had, so the SP4 swap theory isn't valid.  An SP4 would have been nice though.
    2018-07-24T19:40:17+00:00
    My bad, the SurfaceProUeFI_20500FA file is a .cap.
    2018-07-24T19:49:16+00:00
    Barb,
    I'm getting old and my memory is fading, but my recollection is that all my issues began after updating the BIOS, so reinstalling the software will not get me out of the mud.
    2018-07-24T21:47:43+00:00
    What was happening then?  Is that clue helpful?
    PS>net helpmsg (0x490)
    Element not found.
    You might be able to find out more about that "element" in CBS.log (or more likely archived portion) using that timestamp as an index.
